VTP
Nov 25th, 2007
I configured in a switched network VTP .
It is posible that the VTP server to send information about VLAN's with the ports configured for each VLAN?
I configured on the VTP server Vlan 2 and Vlan 3, and port fa0/2 in Vlan 2 and port fa0/3 in Vlan 3. The VTP client is getting the information about Vlan's along with the ports fa0/2 and fa0/3. I know that ports configured for each Vlan are localy significant. No matter what port I configure on VTp client , it will be updated with the configuration fron VTP server.
I configured this on Boson simulatior , but it is posible on real cisco equipments ?
Overall Rating: 5 (1 ratings)
bvsnarayana03 Sun, 11/25/2007 - 06:18
VTP server only sends the VLAN information to VTP client & not the ports associated with VLANs.Also for the server & client to share VLAN info, they have to be on the same VTP domain & if passwords are configured then they have to match on all switches in domain.
Config revision number is incremented everytime, there is a change associated with VLAN.
pls rate if helped.
Spinu Viorel Sun, 11/25/2007 - 07:30
i am preparing for ccna exam and i worked only with software simulators.
i learned exactly as u wrote... i think that is a software bug.
i wanted to hear somebodyelse opinion, just to be certain.
thank u!
