PoE for the 1250
Nov 25th, 2007
Which currently available switches are able to provide PoE to a 1250 AP with both the 2.4 GHz and 5.0 GHz radio modules? I know the switch must support at least 18.5 W and that if only one radio module is installed that it is supported by existing 802.11af switches. I want the work horse solution, both modules/no power injector/using just a PoE switch.
grzegorz.ciolek Mon, 11/26/2007 - 00:17
As far as I know there is no CAT SW form Cisco which support dual radio on 1250 at the moment. You can turn on only one band. But in near future Cisco will release new revision of Cat 4500. It will be 4500-E. Also new line card WS-X4648-RJ45V-E which supports POE dual radio.
bfowles Mon, 01/21/2008 - 06:37
Anyone know if Cisco has released new code to enable both of the AP1250 radios to be supported by a 6500 PoE line card (WS-X6148A-GE-45AF) yet.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
