Brandon Buffin Mon, 12/10/2007 - 12:47
  • Purple, 4500 points or more
If you have a partner CCO login, go to the following link:
http://www.cisco.com/web/learning/le36/learning_partner_e-learning_connection_tool_launch.html
Click Launch -> Course Offerings -> Specialization -> SMB Specialization -> Engineer Learning Map
You will see the web-based course SMB Solutions for Engineers.
Hope this helps. If so, please rate the post.
Brandon
ifective8081 Fri, 01/04/2008 - 01:20
Yes that's exactly the place where you can find the course material.
