Reuse GBIC
Nov 25th, 2007
Dear Sir,
I have GBIC for WS-X6416-GBIC (on 6506) and now I am replacing the 6506 with 4506E. WS-X4418-GB will be used this time.
Can I use the old GBIC on WS-X6416-GBIC?
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 11/26/2007 - 00:55
Hi Joseph
You don't say which GBIC it is.
The WS-X4418-GB supports the following GBIC's
WS-G5484, G5486, G5487
The WS-X6416-GBIC supports
WS-G5483, WS-G5484, G5486, G5487
The WS-G5483 is a for Cat5 so unless you are using that in your 6416 module you should be fine.
Attached is the full matrix for GBIC compatability between Catalyst switches.
