Warning message
setup small bussiness
Nov 26th, 2007
I puchase two cisco router to connect my two offices located in different cities.I also puchase dsl connection.how can I connect my two offices.how to setup the Ips address.thanks
graemeporter Mon, 11/26/2007 - 01:22
  • Bronze, 100 points or more
Hi there!
Assuming both your Cisco routers have a hardware VPN module, your simplest option is to create a VPN tunnel between the two sites. You would also need to have an IOS image loaded on your routers that supports crypto.
You can check by logging into the router and typing "show version" - if it gives this piece of information, then you know that your router has a VPN module:
"1 Virtual Private Network (VPN) Module"
If you don't have VPN modules in your routers, then I'm fairly certain that you can't do what you're looking to do securely. Assuming both your DSL lines give you a static IP address, you could begin routing between them, but your traffic would not be encrypted and is therefore not secure.
Some routers (i.e. Cisco 1700 series) support VPN, but don't come with the module fitted as standard; with some routers, it is possible to buy the module as an add-on.
I hope this is of some help to you. Good luck!
Kind regards,
Graeme
John Patrick Lopez Mon, 11/26/2007 - 01:46
If ever your IOS doesn't support crypto, you can always use GRE tunneling. If it does then you can run GRE/IPSEC for additional security. This way, you can run routing protocol between your 2 sites. Let's just hope that they give you a static IP address.
regards,
John
siddiq_afridi Tue, 11/27/2007 - 06:37
plz send me all details to setup vpn module including router commands to setup vpn .thanks
graemeporter Tue, 11/27/2007 - 07:31
This configuration template works well for us. When correctly entered, you should find that it sets up an IPSec tunnel between the two routers, and runs a GRE tunnel over it. This gives a nice secure connection.
You will need to route each site's inside subnet across the tunnel so that devices on each site can contact each other.
Hope this helps!
On your Site A router:
interface Loopback0
ip address 255.255.255.255
ip access-list extended GRE-TO-SITE-B
permit ip host host
ip route 255.255.255.255
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp key address no-xauth
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto map IPSEC-VPN 100 ipsec-isakmp
description VPN Link to Site B
set peer
set transform-set 3DES-SHA
match address GRE-TO-SITE-B
interface Tunnel100
description GRE Tunnel to Site B
bandwidth 2000
ip address 255.255.255.252
ip mtu 1420
ip route-cache flow
ip tcp adjust-mss 1380
load-interval 30
keepalive 20 6
tunnel source Loopback0
tunnel destination
On your Site B router:
interface Loopback0
ip access-list extended GRE-TO-SITE-A
permit ip host host
encr 3des
group 2
description VPN Link to Site A
set peer
match address GRE-TO-SITE-A
interface Tunnel100
description GRE Tunnel to Site A
bandwidth 2000
ip mtu 1420
ip route-cache flow
load-interval 30
keepalive 20 6
tunnel destination
Kind regards,
Graeme
