ASA 5550
Nov 26th, 2007
Dear All,
Can any one tell me the known bugs in ASA 5550?
The problem i am facing is that nat 0 entries get deleted automatically when no nat access-list is applied with protocol and ports.
also static natting enties were deleted twice in the device.
please advise the reason for the same.
hartog Mon, 11/26/2007 - 03:54
Software issue ? Which version do you run ?
Check out the bug toolkit on CCO.
good luck
sanbhardwaj Mon, 11/26/2007 - 04:00
ios version is 7.1(2). I have already checked the bug list. Coul not find anything relating to this.
i am using two fibre interface. The no nat entries are deleted automatically without any changes being made in the device.
