transparent mode Firewall with 4 ports transparent mode Firewall with 4 por
Nov 26th, 2007
Dears,
i have Firewall with 4 ports FE is configured as transparent mode..... how many interfaces i can configure in this mode.
i heared just one output interface and one input interface i can configure in this mode...is that true?
or can i configure 2 FE as output and 2 FE as Input.
thx for any advice or help.
sachin.verma Mon, 11/26/2007 - 23:52
Kindly provide the software and hardware details of your firewall.
regards
Sachin Verma
johann.giese Thu, 02/14/2008 - 19:45
Dou you have info about this ?
Can you configure only 2 or 4 interfaces ?
mtloader Sun, 02/17/2008 - 11:25
Greetings,
Accoding to the ASA manual:
Note Transparent firewall mode allows only two interfaces to pass through traffic; however, on the The ASA 5510 and higher adaptive security appliance, you can use the Management 0/0 interface (either the physical interface or a subinterface) as a third interface for management traffic. The mode is not configurable in this case and must always be management-only.
Also if you desire yopu can configure your device in multiple context mode and use all 4 interfaces. 2 for each context.
Hope this helped.
