pix 7.1 (cant vpn behind it)
Nov 26th, 2007
hi,
i have a cisco 800 box which want to do site to site vpn. it works fine but when its is behind my pix device it cant.
I get this error from adsm log of pix
"305006: regular translation creation failed for protocol 50 src difc-adsl:192.168.200.40 dst outside:194.153.138.16"
srue Mon, 11/26/2007 - 05:51
  • Blue, 1500 points or more
what OS is your PIX running?
does the 800 series box have a static nat entry on the PIX?
the 800's remote vpn peer, is it using the nat'ed entry for it's peer?
this could be either a nat-t issue, or ipsec inspection issue. the fix though, depends on your PIX OS version (if that's the problem).
adil.ibrahim Mon, 11/26/2007 - 06:08
I have got pix 7.1 running on my firewall.pls have a look at the attached file for conf details.
adil.ibrahim Mon, 11/26/2007 - 20:40
it still does not fix the problem. I am still getting the error on adsm log :(
adil.ibrahim Mon, 11/26/2007 - 21:01
i added the command "static (difc-adsl,outside) 80.227.216.2 192.168.200.20 netmask 255.255.255.255" and the message has disappeared from the log and tells me that
please see some adsm logs below:
6|Nov 26 2007 20:34:23|609001: Built local-host difc-adsl:192.168.200.40
6|Nov 26 2007 20:34:22|609002: Teardown local-host difc-adsl:192.168.200.40 duration 0:00:00
3|Nov 26 2007 20:34:22|305006: regular translation creation failed for protocol 50 src difc-adsl:192.168.200.40 dst outside:194.153.138.16
6|Nov 26 2007 20:34:22|609001: Built local-host difc-adsl:192.168.200.40
6|Nov 26 2007 20:34:21|609002: Teardown local-host difc-adsl:192.168.200.40 duration 0:00:00
3|Nov 26 2007 20:34:21|305006: regular translation creation failed for protocol 50 src difc-adsl:192.168.200.40 dst outside:194.153.138.16
6|Nov 26 2007 20:34:21|609001: Built local-host difc-adsl:192.168.200.40
6|Nov 26 2007 20:33:22|609002: Teardown local-host difc-adsl:192.168.200.40 duration 0:00:00
3|Nov 26 2007 20:33:22|305006: regular translation creation failed for protocol 50 src difc-adsl:192.168.200.40 dst outside:194.153.138.16
6|Nov 26 2007 20:33:22|609001: Built local-host difc-adsl:192.168.200.40
6|Nov 26 2007 20:33:20|609002: Teardown local-host difc-adsl:192.168.200.40 duration 0:00:00
3|Nov 26 2007 20:33:20|305006: regular translation creation failed for protocol 50 src difc-adsl:192.168.200.40 dst outside:194.153.138.16
6|Nov 26 2007 20:33:20|609001: Built local-host difc-adsl:192.168.200.40
6|Nov 26 2007 20:33:03|609002: Teardown local-host difc-adsl:192.168.200.40 duration 0:02:38
5|Nov 26 2007 20:32:57|111008: User 'enable_15' executed the 'no static (difc-adsl,outside) 80.227.216.2 192.168.200.40 netmask 255.255.255.255' command.
6|Nov 26 2007 20:32:57|305010: Teardown static translation from difc-adsl:192.168.200.40 to outside:80.227.216.2 duration 0:09:43
6|Nov 26 2007 20:30:25|609001: Built local-host difc-adsl:192.168.200.40
6|Nov 26 2007 20:30:08|609002: Teardown local-host difc-adsl:192.168.200.40 duration 0:04:01
6|Nov 26 2007 20:28:08|302016: Teardown UDP connection 1393931 for outside:194.153.138.16/500 to difc-adsl:192.168.200.40/500 duration 0:02:01 bytes 4756
6|Nov 26 2007 20:26:06|302015: Built outbound UDP connection 1393931 for outside:194.153.138.16/500 (194.153.138.16/500) to difc-adsl:192.168.200.40/500 (80.227.216.2/500)
6|Nov 26 2007 20:26:06|609001: Built local-host difc-adsl:192.168.200.40
