Cisco Pix PDM time-out
Nov 26th, 2007
hi all,
I have a problem with my cisco pix 501 and hope someone here could help me.
Im a beginner so go easy on me :D
My problem is that my PDM seems to time out after 30 to 60 seconds, obviousley i dont want it to do that else i wouldnt post it here ;)
When it times out and i want to save a config it gives the error;
[ERR]write mem PDM received an error while sending this command. Click Resend and if the browser
prompt you to verify a new certificate or to provide a username/password, please do so.
i tried changing the different time-out options via the console like timeout xlate, timeout conn, timeout h323 timeout uauth with no result.Also i tried to delete the certificate via the commands;
ca zeroize rsa
ca generate rsa key 1024
this didnt work either.
The problem occurse when i use a config with a user and without one.
Can anyone help me with this? thanks in advance.
Greetings Bas
p.s. The pix version is 6.3(5) and the PDM version is 3.0(4)
baskleian Wed, 11/28/2007 - 02:08
solved it!
It was a java problem, downgrading to version 5 update 5 did the trick for me!
