11-26-2007 04:47 AM - edited 03-14-2019 01:34 AM
When an agents ends a call, how can you make a delay on 10-15 secs before he appears as ready in the system?
Solved! Go to Solution.
11-26-2007 06:25 AM
You will have to set up in the CSQ configuration webpages (RmCm), for each CSQ you have set up in IPCCX, you have to check the 'Automatic Work' to 'Enabled' and the 'Wraup time' to 10-15 seconds.
Hope this helps,
Juan Luis
11-26-2007 05:20 AM
You would set up a wrap-up time of 10-15 seconds. After that 10-15 seconds, the agent will be available agian.
Depending of the producto you are using, IPCC Express or Enterprise, this wrap-up state is configured in a different manner.
Hope this helps,
Juan Luis
11-26-2007 06:18 AM
What i got is IPCC Express
11-26-2007 06:25 AM
Hope this helps,
Juan Luis
11-26-2007 06:36 AM
Thank you very much Juan Luis
11-26-2007 06:38 AM
Don't forget to rate helpful posts ;-)
Juan Luis
11-26-2007 06:39 AM
Way ahead of you ;)
Thanks again...
