2 PPPoE connection on ASA
Nov 26th, 2007
is it possible to use, two interfaces with PPPoE connections. One interface for outgoing connections and the other one for a DMZ Server incoming connection.
Outgoing connections will use default route, incoming connections should be use a static mapping address.
Is this possible, any documantation for this case ?
Thx in advance and sorry for my bad english.
didyap Mon, 12/03/2007 - 09:42
Two PPPoE connections on same ASA can be done but PPPoE is not supported if you are using it for failover or redundancy.
