6509 IOS upgrade
Nov 26th, 2007
Dears
i have 6509 switch and i want the switch to boot from IOS image in Disk1 instead of the image in bootflash can anyone give me steps to do this task
f-cagica Mon, 11/26/2007 - 05:54
from your post i assume you are running IOS and not CATos.
Did you try:
boot system disk1: and reload?
seegomaa Mon, 11/26/2007 - 06:17
thanks for reply
i tried this command and there is conflict in my readings because some documents i found the command boot system flash disk1:
and sometimes boot system disk1: and sometimes boot system flash sup-disk1:
i don't what is the right command
thanks
jarredtaylor Mon, 11/26/2007 - 06:41
I always use the 'boot system flash ' command to specify the boot image. The 'flash' keyword instructs the device to boot from an image stored in a flash memory device (whether that's bootflash:, sup-bootflash:, disk1:, etc.).
HTH,
Jarred
f-cagica Mon, 11/26/2007 - 07:29
boot system disk1:... will work as well. Either will achieve your goal.
