2950 Trunking question
Nov 26th, 2007
Good Morning,
How do I get the switchport mode trunk off of this? Really I would like 0/23, 0/24 to be the same as 0/22.
interface FastEthernet0/22
switchport access vlan 2
no ip address
spanning-tree portfast
spanning-tree guard root
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no ip address
Thank you
Kevin Dorrell Mon, 11/26/2007 - 06:19
  • Green, 3000 points or more
If you want them to become access ports, then switchport mode access. However, that would leave the command switchport mode access in the config.
If you want it to be dynamic, which is the default, and what is currently on F0/22, then default switchport mode.
Personally, if you want them to be access ports, then I prefer to tie them down with a switchport mode access.
Kevin Dorrell
Luxembourg
