PBR question
Answered Question
Nov 26th, 2007
Hi all,
Quick question relating to policy based routing. If I have a route-map which does:
Match ip address 10
access-list 10 has a source and dest IP, but there is no Set clause configured.
What will happen when a packet matches the access-list?
As I understand it the packet will be routed by the routing engine and the route-map is effectively doing nothing.
Can someone else confirm please?
Correct Answer by bvsnarayana03 about 9 years 6 months ago
You are right. No effect. Pkts will be routed as in the routing table.
Overall Rating: 3.5 (2 ratings)
Correct Answer
bvsnarayana03 Mon, 11/26/2007 - 06:08
  • Silver, 250 points or more
