UC520 and FXS
Nov 26th, 2007
Hi to all,
two simple question:
1) can I use one of FXS port builted-in the UC520 to connect a modem of fax server (like Microsoft)?
ATA186 doesn't manage modem (only fax).
How have to connect FXS port to route the incoming call from a BRI to a particular FXS port. (I never use fxs!!!)
2) Is the access-list in UC520 possible to manage only by CLI? I find a easy way (like SDM) to manage the default access-list. SDM is not compatible and Configuration Assistant does not manage ACL.
Can I delete all ACL in uc520?
Thank you very much.
Augusto.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Mon, 11/26/2007 - 09:38
Augusto,
1. yes, configure a pots DP with destination-pattern same the called number.
2. you can use the web interface for IP telephony. Yes you can delete all ACL if no special reason to have them.
