SNMP trap Interface Description
Nov 26th, 2007
I am trying to get our SNMP monitoring software to show interface descriptions for our Cisco devices when it receives up/down traps. It shows everything else for an interface, apart from the description. The software developers told me that it would be down to Cisco SNMP agent, rather then their software.
Does anyone have any ideas?
Overall Rating: 4 (1 ratings)
Joe Clarke Tue, 11/27/2007 - 11:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
For what device? Our proprietary link traps include ifDescr as a varbind unless snmp-server trap link ietf is configured. In that case, the traps will only contain ifIndex, ifAdminStatus, and ifOperStatus.
Joe Clarke Tue, 11/27/2007 - 12:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, you're right. We will include extra varbinds (not defined in the MIB) after the MIB-defined varbinds within the trap PDUs.
VictorAKur Wed, 11/28/2007 - 03:57
The problem is that for the OID ifdescr I get the value of FastEternet x/x for example, not the actual text description I have configured on it.
yjdabear Wed, 11/28/2007 - 07:07
  • Gold, 750 points or more
Depending on the type of originating [Cisco] device, the descriptive labels manually typed in could be in ifName (PIX/CatOS) or ifAlias (IOS).
Joe Clarke Wed, 11/28/2007 - 11:19
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The local descriptions will not be sent. This kind of information is usually left up to the management application to fetch upon reception of the notification.
