Upgraded pix 515e more ram + 4 port nic card - see mem not 4 port nic
Nov 26th, 2007
here is my show version:
Cisco PIX Firewall Version 6.2(3)
Cisco PIX Device Manager Version 2.1(1)
Compiled on Thu 17-Jul-03 08:16 by morlee
gatekeeper up 8 mins 6 secs
Hardware: PIX-515E, 64 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is 000b.bed3.7e29, irq 10
1: ethernet1: address is 000b.bed3.7e2a, irq 11
2: ethernet2: address is 0090.277c.01be, irq 5
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES: Disabled
Maximum Interfaces: 3
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
Serial Number: 807020480 (0x301a27c0)
Running Activation Key: 0x49e6200d 0x2bb6f133 0xcd7f6650 0xf9fd8a70
How can I see the new 4 port nic ?
where can i get new IOS:
Cisco PIX Firewall Version 6.3(5)
Cisco PIX Device Manager Version 3.0(4)
so that I can see my 4 port nic card and also enable VPN 3DES
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Mon, 11/26/2007 - 12:23
please do the whole show run to see all information including bottom part.
Most likely you have restricted license (R), if so you need to upgrade license to (UR) unrestricted . R is limited to three interfaces whereas (UR) is for total of 6 physical interfaces.
to upgrading 515E from R to UR you need software license upgrade part number #
(PIX-515-SW-R-UR= )
Licensing Software features
requires CCO login
Licensing and Activation Keys
Also if you can upgrade that code to 6.3(5) and PDM as well.
pls rate any helpful post !
