Collin Clark Mon, 11/26/2007 - 11:02
You'll learn more if you figure out the problem yourself, so I won't provide the answer. However, check out this link (especially the bottom portion) and it will help you work out the answer.
pipemajor Mon, 11/26/2007 - 16:36
Actually, the solution is already provided to you.
This is a VLSM problem. You need to learn to associate a given subnet mask with the number of hosts it provides. Then match the number of hosts with the problem criteria.
Hint: Learn your blocksizes... And a point-to-point serial link is almost always a .252 mask (/30).
mailziyad Tue, 01/08/2008 - 00:38
its easy.subnetting is easy if u remember this calculation.since its class c subnetting we wil start from 25 = 128, 26 = 192, 27=224,28 = 240 ,29= 248,30=250 ,31=252
