3750G-PS-S(48) PoE?
Nov 26th, 2007
I know there is a simple answer for this but I need confirmation. The 3750 mentioned above states that it does PoE on all 48 ports. Is that all ports can do PoE at the same time without a power upgrade? I need to support 12 LWAPs and don't know if I should but one 3750 or two. Thank you in advance.
Collin Clark Mon, 11/26/2007 - 10:58
  • Purple, 4500 points or more
All 48 ports can supply power at the same time. The switch does have a maximum capacity of power in can provide (current link is broken), but 12 AP's should be OK. You'll want to verify when Cisco.com is back online or contact your local SE.
HTH and please rate.
kpaynecisco29 Mon, 11/26/2007 - 11:01
After examining the gonfig guides for the 1130 LWAPs and the 3750 I also found out that 12 APs would work fine on this. Thank you for your help!
