11-26-2007 10:41 AM - edited 03-15-2019 07:25 AM
Cisco 2801 (revision 7.0) with 234496K/27648K bytes of memory.
Processor board ID FHK1143F2WC
2 FastEthernet interfaces
1 terminal line
1 Channelized (E1 or T1)/PRI port
2 Voice FXS interfaces
2 Voice E & M interfaces
3 DSPs, 48 Voice resources
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
What does revision 7.0 means? I have seen revision 6.0 etc. Thank you.
Solved! Go to Solution.
11-26-2007 10:48 AM
These are hardware-level revision number for the motherboard, and do not influence the operations at all, that is, any revision number is supposed to work fine as another.
11-26-2007 10:48 AM
11-26-2007 10:51 AM
Thank you! So can I say, the higher revision is better?
11-26-2007 12:49 PM
No, there are no better revisions, all work the same and make no difference to the user.
Thanks for the nice rating and good luck!
