ISDN BRI
Answered Question
Nov 26th, 2007
Unified express ver 4.1
VIC2 bri s/t card (2 port) when dialpeer is configured to use trunkgroup it fails when trying to place a call, if I configure my dial-peer to use either of the ports on the card it works fine.
I am using the exact same config for trunkgroups, that have worked in the past, the only difference was that the card that worked with trunkgroups was VIC 2 bri NT/TE, does that make any difference?
Correct Answer by paolo bevilacqua about 9 years 8 months ago
VIC-2BRI-S/T-TE is not supported in the 2801. See 6th table in:
http://cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
I don't know why it actually works in "non-trunkgroup mode" for you, but unfortunately not being officially supported, you won't be able to get help from the TAC for this case. So using the correct part is probably the only solution.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 11/26/2007 - 12:55
  • Hall of Fame,
    Founding Member
Hi, can you clarify with "show diag" which exact card are you referring to ?
silex Mon, 11/26/2007 - 13:10
the card I have been successful with is
VIC2-2BRI-NT/TE ( on a previous customer site) ,
and the card I have been supplied and asked to configure is
VIC-2BRI-S/T-TE
As I am in UK I have set compand type to A-law
I have configured a trunkgroup and have set the dial-peers to use the trunkgroup.
point-to point setup and static TEI is also cfgd.
layer 2 shows multiple frame established.
however when both ports are connected to pstn,
I am unable to make a call, I just wonder If I have missed something.
paolo bevilacqua Mon, 11/26/2007 - 14:55
  • Hall of Fame,
    Founding Member
Whic router and IOS are you using ?
silex Mon, 11/26/2007 - 22:10
router is 2801 and the ios is 12.4(15)T
Correct Answer
paolo bevilacqua Tue, 11/27/2007 - 06:57
  • Hall of Fame,
    Founding Member
silex Tue, 11/27/2007 - 07:28
Paolo,
that is a lifesaver, I had a feeling something wasn't right. many thanks, I didn't even know this chart existed. If I could rate your post at 10 points I would. many thanks, that has saved me a lot of heartache
paolo bevilacqua Tue, 11/27/2007 - 07:35
  • Hall of Fame,
    Founding Member
You are very welcome and I wish you the best luck in upcoming projects!
