Rob Huffman Mon, 11/26/2007 - 12:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
julienf28 Mon, 11/26/2007 - 13:25
This helps a lot except I've taken look at our gateways and they are indeed MGCP :( So that said, I will do some more research on my part but would you know what it would take to switch from MGCP to H.323?
Rob Huffman Wed, 11/28/2007 - 07:08
  • Hall of Fame,
    Founding Member
Hi Julien,
This would be a very complicated (but not impossible) change due to the way H.323 is configured.
Adding a Cisco IOS H.323 Gateway
Follow these procedures to add a Cisco IOS H.323 gateway to Cisco CallManager.
Before You Begin
Before configuring a Cisco IOS H.323 gateway for use with Cisco CallManager, you must configure the gateway by using the Cisco IOS command-line interface (CLI). Compared to MGCP gateways, H.323 gateways require more configuration on the gateway because the gateway must maintain the dial plan and route pattern.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00802deb06.html#wp1311511
I might be tempted to speak with your service provider to see what they can do before I went this route :)
Hope this helps!
Rob
