Trunking Cisco AP and ASA
Hi all,
I think I know the answer to my post but I would like a second opinion.
I am trying to trunk a Cisco 1200 AP to an ASA 5505. The AP must have a native VLAN on VLAN 1 according to this link:
The ASA 5505 supports trunking but no native VLAN support. (see bottom of step 2).
Then I assume that if I want to do this, I'll have to put a switch in the middle, right?
The other option is to use a WLAN controller and tunnel all VLAN within the LWAPP tunnel.
Any other suggestions?
srue Mon, 11/26/2007 - 11:32
you are correct, that in trunking mode, there is no native vlan support.
Cisco makes some inexpensive switches that would probably suit your needs.
