NM1-T3 card in 3745 doesn't come up automatically
Nov 26th, 2007
I have a 3745 that has an ATM DS3 card in slot 1. We're adding a 2nd DS3 so I installed an NM1-T3 card in slot 2.
I was able to create the interface and configure it with no issues.
card type t3 2
controller T3 2/0
However here's my problem - if the interface goes down for any reason (manual shut/no shut, cables removed, reconnected, etc) the interface stays down/down until I go into the controller config and put the controller in loopback mode, and then take it back out of loopback mode. Then the interface and line come up. And it passes traffic with no problems.
I need to get it to come up automatically though, in case there's a power outage, telco problem, whatever.
I've confirmed the settings with the carrier and everything seems to match. Here are controller and interface configs (ip address removed).
sh controller t3 2/0
T3 2/0 is up.
Applique type is Subrate T3
No alarms detected.
MDL transmission is disabled
FEAC code received: No code is being received
Framing is C-BIT Parity, Line Code is B3ZS, Clock Source is Internal
interface Serial2/0
ip address xxx.xxx.xxx.xxx 255.255.255.252
encapsulation ppp
dsu bandwidth 44210
no cdp enable
sh int ser2/0
Serial2/0 is up, line protocol is up
Hardware is DSXPNM Serial
Internet address is xxx.xxx.xxx.xxx/30
MTU 4470 bytes, BW 44210 Kbit, DLY 200 usec,
Encapsulation PPP, LCP Open
Open: IPCP, crc 16, loopback not set
Keepalive set (10 sec)
Last input 00:03:20, output 00:00:10, output hang never
Last clearing of "show interface" counters 00:24:56
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 119000 bits/sec, 0 packets/sec
160350 packets input, 206824924 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
55 packets output, 880 bytes, 0 underruns
0 carrier transitions
DSU mode 0, bandwidth 44210, real bandwidth 44210, scramble 0
Thanks.
Christina
