11-26-2007 01:53 PM - edited 02-21-2020 03:24 PM
I have a Cisco PIX with a site-to-site vpn and also client-to-site vpn. I can authenticate to the vpn and connect, however, I cannot access a pc on the internal network via Remote desktop. I have attached my config. Can someone tell me if I am missing something?
Config attached:
GDA
11-26-2007 01:57 PM
11-26-2007 04:37 PM
Hello.
I would suggest your not performing a no NAT (NAT 0) for traffic from the 192.168.50.x network to the 192.168.50.x networks.
Add the following and see how that goes....
access-list nonat permit ip 192.168.50.0 255.255.255.0 192.168.50.0 255.255.255.0
You may wish to add it with the correc subnets and mask for the internal and IPSEC client vpn ranges.
Tim
11-27-2007 10:22 AM
I think I already have the access-list nonat permit ip 192.168.50.0 255.255.255.0 192.168.51.0 255.255.255.0. Should I just remove the command: nat (inside) 0 access-list nonat?
GDA
12-02-2007 10:05 PM
No.
Your current acl is for the 50.0 to the 51.0 networks.
You have indicated your trying to get to an internal host, which i presume is on the 50.x subnet.
Your IP pool for IPSEC clients is also 50.x, hence your nat statement does not match.
Tim
12-03-2007 01:38 AM
Or you could just change your IP pool Pool1 range to 192.168.51.200-192.168.51.254 so it matches your ruleset, and see how that goes.
Kev
