3560G port security problems
Nov 26th, 2007
Here's the issue:
I have all ports on my switch configured as such
switchport mode access
switchport port-security (max 1)
switchport port-security mac-address sticky
The problem I'm having is that I have tried to switch systems on two ports that have already recognized the mac-addresses.
I conducted the following on both interfaces in preparation for moving the systems:
no switchport port-security mac-address sticky
shut
(once systems were moved)
no shut
After doing this one of the ports give me the port security violation error and shuts down the port. The other port is just fine.
How do I effectively clear the settings from the ports. I've tried everything to include the...
clear port-security (sticky/dynamic/configured) address (offended mac address) ....as well as
clear port-security (sticky/dynamic/configured) int (interface shutting down) access
I'm running IOS 12.2.(25)SEE2.
chad.webb Tue, 11/27/2007 - 07:11
I found the resolution late yesterday.
It appears that the only thing that worked was in addition to removing the port-security settings I had to "no switchport mode access" the interface along with a shut/noshut and add the "switchport mode access" and port-security setting back.
That seem to clear the interface so that it would not err-disable anymore and recognize the new mac-address for the swapped system.
I tried all of the clear port-security commands with no resolution to the problem.
Hope this helps someone else.
