mac-address filter on cisco 871
Nov 26th, 2007
i want to configure a simple mac-address filter, to allow only one PC on the FE0 Port on a cisco 871.
interface vlan 1
bridge-group 1
bridge-group 1 input-access-list 700
access-list 700 permit 00c0.0404.091a 0000.0000.0000
but it doesnt't work :-(
i think, i have forgot something ! thanks in advance.
Hi, you may need to use the switchport port-security commands, you can hardcode (static) and mac-address to the switch port or limit the number of address learned on any interface port. Try the commands from the document below, they have help me in the past to keep user from jacking their personal computer into dataport and logging onto the net.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/port_sec.html
wolfgangz Wed, 11/28/2007 - 07:05
Hi, thanks for your reply
on the cisco 871 plattform, you cannot configure port security :-(
router(config-if)#switchport ?
access Set access mode characteristics of the interface
mode Set trunking mode of the interface
priority Set 802.1p priorities
trunk Set trunking characteristics of the interface
voice Voice appliance attributes
so i think the only way is to configure a bridge-group.
cu
