Problem of EIGRP
Nov 26th, 2007
Hi my seriors, I am new in networking field and preparing for lab is three router r1,r2,r3.
eigrp enabled,network=,
s0=dte,connected to r2 so,dce.
r2=s0=,,dec cable
s1= , dec cable att
r3=s1= dte attached to r2 on s1.
eigrp enable,network=,
My question. 1.Network lo0 on r3 not beign advterised in this configuration. but when i changed the network command on r3 form to ,other routers noted the network and added into their table. I could not understand. Thanks for reply.
Kevin Dorrell Mon, 11/26/2007 - 14:59
If you have configured network in EIGRP, then have a look at a show run to see how it has handled it.
In fact, the network command is expecting a wildcard mask (like an access-list does), and not a subnet mask. You need network instead.
But in any case, that network command would not cover your Lo0 on R3. You would need something like network
Kevin Dorrell
