ACS 4.1.1 Admin GUI breaks after importing internal database
Nov 26th, 2007
has any one got a idea why the Administrative GUI would cease to function after importing a Internal database from Windows version of ACS to ACS Solution Engine? Both are ver. 4.1.1 OS. Thanks for any Ideas on this.
ccbootcamp Mon, 11/26/2007 - 22:12
Did you make sure the ACS services are running after the import is done? I've seen the import database function stop of the services and not re-start them after the import is complete.
-brad
www.ccbootcamp.com
Richard Atkin Tue, 11/27/2007 - 04:16
Doesn't address the problem directly, but you could add a new GUI Admin via the ACS Console.
Login over the console (115000, 8, N, 1, N)and type;
add guiadmin
then follow the wizard.
HTH,
Richard
