WLC Supported Traps (w/OID)
Nov 26th, 2007
I currently have a WLC 2006, but would like to know what kind of traps all of your WLC's support (specifically the Model 2006) by version.
Current firmware is v4.0.206.0
I can view the mib files, but it doesn't tell me which WLC and which version is supported.
Walt
Anonymous (not verified) Mon, 12/03/2007 - 13:23
You can see traps supported on controller itself. Go to the management tab and click on Trap controls under SNMP in the Left Hand side.
wbenton-0 Mon, 12/03/2007 - 15:47
Yes, I can see which traps are supported, but even if I specify to use SNMP v1, the actual incoming traps to the NMS are all v2.
See the attachment with transcripts below:
Telnet Packets 229, 3186 & 5351 specifically shows the following:
SNMP v1 Mode.... Enable
SNMP v2c Mode... Disable
SNMP v3 Mode.... Disable
Telnet Packet 571 specifically shows the following:
SNMP v2c Mode... Enable
Telnet Packet 1591 specifically shows the following:
SNMP v1 Mode.... Disable
But regardless of what the above telnet information shows you, if you filter on all packets with a dstport number of 162 (i.e. all traps), notice that the WLC-2006A is sending ONLY SNMP v2 Traps.
There seems no way to configure the WLC-2006A to send SNMP v1 traps.
wbenton-0 Sun, 12/09/2007 - 21:01
How does one configure it to send SNMP v1 traps?
Setting SNMP to v1 doesn't change a thing. It Still sends SNMP v2c traps!
Mehdi_ab Thu, 12/20/2007 - 15:24
That setting is only to allow the WLC to be managed using snmp v1. Traps would still be sent using v2c.
Trending Topics - Security & Network
