Please Suggest.
Nov 26th, 2007
  • Silver, 250 points or more
Dear All,
Please find the output of my router. I'd tried to implement some QOS to my router. But after implementing the same I found that the serial interface's available Bandwidth is showing 8 kilobits/sec only.
Also my target is to putting best value for ABC_ACL data. Next DEF_ACL data and then GHI_ACL data. Find the attachment for mote details.
Please suggest how can I put all this required traffic to a QOS.
Thanks & Rgds
Go San
Kevin Dorrell Tue, 11/27/2007 - 00:10
  • Green, 3000 points or more
Please could you post the configs. The attachment seems to be missing.
Kevin Dorrell Wed, 11/28/2007 - 02:47
8 kbps is what you are guaranteed to have left for you default class fair queue, after it has reserved 44 kpbs for class ABC, 6 kbps for class DEF, and 6 kbps for class GHI.
That does not mean that your default class is limited to 8 kbps. If any of the other classes are not using their full reservation, anything that is left over can be used by the default class. But if the classes are using their full reserved bandwidth, then yes, 8 kbps is all that is left available for the default class.
Kevin Dorrell
Luxembourg
