Cisco 7960 is not booting with PoE port
Nov 26th, 2007
I have Cisco 7960 ip phone, i have connected that in a PoE port, the phone doesn't boot, so what i use to do is, i use a power adaptor, then the ip phone bootz after the ip phone is booted completely, i remove the power adaptor, the ip phone functionz normally, this practice i am doing it when ever i switch OFF & switch ON the ip phone. I also tried connecting to the existing working IP phonez which doesn't even require a power adaptor for booting. those phones works perfectly, i tired replacing with this ip phone on that, the problem is same.
Anand S Tue, 11/27/2007 - 04:42
forgot to include in the my previous post, all these ip phones are connected on 3COM switch.
yenlung Mon, 12/03/2007 - 01:30
No enough power on the 3com switch...
During start up, it will require a lot of power, as compare to running in operation mode
Paolo Bevilacqua Mon, 12/03/2007 - 02:01
Actually the reason is that the 7960 is a pre-standard PoE phone, so called cisco PoE.
As fa as I'm aware, the 3com switch doesn't supports cisco PoE.
