Remove ACL from ACE(object-group)
Nov 27th, 2007
I need to remove only an ACL entry from ACE which i created by adding network object in object-group.....i am not able to do same because all ACL having same line no. and ACL name.
#access-list acl-in line 120 extended permit tcp object-group xxx-xxx-xxx host x.x.x.x eq xxxx
access-list acl-in line 120 extended permit tcp host x.x.x.x host x.x.x.x eq xxx
any idea to remove........
arif786 Tue, 11/27/2007 - 05:53
why can't u copy that exact statement, and go for?
no
srue Tue, 11/27/2007 - 06:01
  • Blue, 1500 points or more
you have to remove it from the object-group. you can't selectively allow only parts of an object group in an ACL.
amit.secure1 Tue, 11/27/2007 - 06:05
I can't remove from object-group because i allow traffic of same source>>>>diffrent destination ip and port.......
if i will remove from object then all acl will be remove for that ip from object-group and other servers will be out of customer access.....
amit.secure1 Tue, 11/27/2007 - 06:01
I tried same but not able to do so, getting below error...
Specified access-list does not exist
srue Tue, 11/27/2007 - 07:13
use two different object groups then.
amit.secure1 Tue, 11/27/2007 - 07:16
i having so many acl with same configuration in diffrent object group so it's very tuff to remove from object-group then add acl in another object-group....
