Today can't manage PIX (6.3) via PDM (3.04)
Nov 27th, 2007
I made some change (ACL) via command line yesterday, and after that I was unable to use PDM to manage the PIX even the config was fallbacked to the day before. The PDM always in the status of "loading PIX Device Manager. Please wait..." Is there any way to fix the problem? any idea is appreciated, thanks
JORGE RODRIGUEZ Tue, 11/27/2007 - 04:18
Check pop-up blockers on browser, try loading pdm from another machine if possible to rule out pdm issues.. usually these symptoms are browser issues related.
amentindustrial Thu, 01/24/2008 - 05:52
I'm experiencing the same issue. Pop-up blockers are indeed turned off. Another thing I'm experiencing is the certificate is invalid. Although installed in the Trusted section to which IE implies, it still just sits there.
