Does CM 6.x support several SIP endpoint registrations from one IP address?
pkovcon634
Title says it all, so has anybody tested if it is possible to register several (IETF) SIP clients to CallManager from the same IP address? In other words, can you run two or more SIP clients in one PC and register both to CallManager but using different credentials?
smalkeric
Level 6
Level 6
On the line side, SIP running on the Cisco Unified IP Phone models 7905G, 7911G, 7912G, 7940G, 7941G, 7941G-GE, 7960G, 7961G, 7961G-GE, 7970G, and 7971G-GE helps customers participate in systemwide, SIP-directed features such as presence and interoperation with third-party SIP services. In addition, line-side SIP support helps enable Cisco Unified CallManager 5.0 to provision, register, and manage specialty and third-party SIP phones.
http://cisco.com/en/US/netsol/ns340/ns394/ns165/networking_solutions_white_paper0900aecd80422c70.shtml
This did not answer my question. I don't want to use Cisco phones, but I want run several 3rd party SIP softphone clients in a PC and register them to CallManager. In this case they all would use same IP. Does this work? (I don't currently have CM installation at hand so I can't test it myself.)
