TDM switching with 3845
Nov 27th, 2007
Dear all,
I have a 3845. In slot 1 and 2, I have a Voice VM-8FXS/DID Port adapter with two NT or TE BRI Voice Expansion Module (4 port). 2 E1 (2 port) Multi-Flex Trunk WAN daughter card in slot 0 are used to connect to the PSTN.
I was able to enter the following commands:
network-clock-participate slot 1
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
But this one doesn't work:
# network-clock-participate slot 2
Slot is empty or does not support clock participate
Any ideas ?
The hardware of slot 1 is the same than
slot 2.
Many thanks
Phil
smahbub Tue, 12/04/2007 - 07:27
Firrst try , no network-clock-participate slot 1, no network-clock-participate wic 0, no network-clock-participate wic 1
then try
Remove the following commands:
