nokia sccp
alessandro.dona
Level 3
Level 3
Can anyone provide any info about how integrate nokia eseries phone with ccme(where download phone software, license and so on)
THX...
Alex
6 Replies 6
pmays
Alex,
I don't do much voice work, (although I am using the e61i with the Call Connect client).
Here is a link to what you're looking for from Nokia:
http://www.businesssoftware.nokia.com/nokia_intellisync_call_connect_for_cisco_downloads.php
You can download the client, you can select the trial license if this is just for testing. There is also documentation.
Hi Perry,
Very good info here! 5 points for posting this up. It looks like this may be only for "full" CCM not CCM Express, is that correct?
Take care,
Rob
the Nokia client 1.1 works with CCM 4.x, 5.x or 6.x, CCME 4.x and later, as well as the UC 500.
Later...
So can you extension dial then with the Nokia phones connected to CCM?
Thanks!
What if i want the Nokia Eseries to connect through public wireless hotspot to my CME 4.x ( internet connection ) ?
Is this possible ?
Mohamed
t.schaffner
Alex,
Please check the Release Notes and you will find the answer:
In Nokia Intellisync Call Connect v1.0, the device type used for Nokia Eseries
devices in Cisco Unified Communications Manager was 7960. In v1.1, it is
either Nokia S60 (Cisco Unified Communications Manager) or Cisco 7970
(Cisco Unified Communications Manager Express).
The old ICC 1.0 used a as device type 7960 which used 4 device units in CUCM 5.x and 6.x, now it uses 5 units :-(
Best regards
Thomas
