policing output side
sjamison76
We have been using the 'shape average' command for our traffic shaping on our output side for the bandwidth we sell to customers. It seems that this might not be the best way to traffic shape a rate (like 15meg) to a customer.
After doing much research, I have changed the 'shape average' to 'bandwidth'. After doing so, the traffic shot right up to the max limit on the output side.
My question is, what is the best way from a SP to shape outbound traffic to a customer? Here is what we had before:
policy-map POLICYOUTPUT
description Customer Access Port Policy (Output)
class class-default
shape average 15789488
policy-map POLICYINPUT
description Customer Access Port Policy (Input)
class CLASSMAPALLTRAFFIC
police cir 15789488
interface FastEthernet0/1
switchport access vlan 202
speed 100
duplex full
service-policy input POLICYINPUT
service-policy output POLICYOUTPUT
Here is what it is set to now:
policy-map POLICYOUTPUT-TEST
class class-default
bandwidth 15360
police cir 15789488
speed 100
duplex full
service-policy output POLICYOUTPUT-TEST
Thanks!
5 Replies 5
pbenin
Hello sjamison76.
We use ME3400 as U-PE for MPLS services.
When we sell sub-rate bandwidth of a port-speed we apply "shape average" as Port-Shaping on output direction.
On input direction we use an aggregate or individual policer.
Important: the CE router must be configured for port-based shaping in the direction of MPLS services.
The system is working and our customers are satisfied.
We do shape average too, but ive noticed two customers who have never been able to hit their top bandwidth mark for some reason. By changing this policy to use just 'bandwidth' they have pegged quite a few times now.
Im just curious what this bandwidth command does, and what the best way to do this would be. And why the shape 'average' seems to not give them the bandwidth they are supposed to be getting.
its just strange...
For ME3400 I know the bandwidth command means "minimum band guarantee" for that Class-map.
Shape average is referred to "maximum band" for a Class-map.
Look at:
http://www.cisco.com/en/US/products/ps6580/products_configuration_guide_chapter09186a008087831b.html
Thanks for the doc, that definately explains things a lot better than the previos doc I had.
Taking a look at the traffic patterns of the customer yesterday he had hit his max limit for about 15 minutes yesterday and kept it pegged since using the bandwidth command and did not go over the limit.
Im more curious now as to when you would want to use the 'shape average' or 'bandwidth' command. If there is precedent over one or the other in different situations. Just seems strange to have two commands that seem to do the same thing.
Thanks for your help pbenin, I appreciate it!
Here is a configuration where the customer buys 50Mbps of total bandwidth, min 10Mbps Class_1 (burstable to 50Mbps) and min 20Mbps Class_2 (burstable to 50Mbps).
class-map match-any CLASS_1
match ip dscp cs1
class-map match-any CLASS_2
match ip dscp cs2
class-map match-any CLASS_3
match ip dscp cs3
policy-map PORT-SHAPING
class class-default
shape average 50000000
service-policy CBPQ
policy-map CBPQ
class CLASS_1
police cir 64000
priority
class CLASS_2
bandwidth 10000
class CLASS_3
bandwidth 20000
speed 100
service-policy output PORT-SHAPING
