2 ssid on 1811 wireless router
Answered Question
Nov 27th, 2007
I am plannign ob buying a CISCO1811W-AG-B/K9 for a small setup. I need to setup two SSID. One SSID will give access to our local LAN to the users. Other SSID will give access to internet. I dont see why it cant be done but just need to have an expert opinion. Can someone help.
Nilesh
Correct Answer by Richard Atkin about 9 years 6 months ago
Yeah, shouldn't be a problem, just set up as usual on the router.
Yeah, you can do that no worries. Just make sure you're familiar with how APs work re: BVI(s), and you'll be fine.
Rgds,
Richard.
Overall Rating: 5 (2 ratings)
Correct Answer
Richard Atkin Tue, 11/27/2007 - 08:03
  • Silver, 250 points or more
Rgds,
Richard.
nileshmathure Wed, 11/28/2007 - 06:51
Thanks Richard for a prompt reply. I have one more question. Does 1811 have DHCP server capability ? Can it assign IPs to both wired and wireless devices. I am sure it will but if otherwise please advise.
Nilesh
Correct Answer
Richard Atkin Wed, 11/28/2007 - 14:49
