Changing Network Class
Nov 27th, 2007
Hi All
Sorry for my lack of knowledge re IOS. I do know that this is wrong and wondering how to change it
router ospf 1
network area 0
network area 29
network area 30
network area 31
That 132 network should be class B. Any tips on how to correct that would be much appreciated.
Thanks in advance
alessandroye Tue, 11/27/2007 - 08:21
Step.1 you should enter to OSPF configuration mode
Step.2 delete 132 network
no network area 0
Step.3 add the corrected network
network area 0
Step.3 in the enable mode, save the configuration.
Or Step.2 and Step.3 go together, u can change the wildcard directly.
alessandroye Tue, 11/27/2007 - 09:09
Router#config terminal
Router(config)# router ospf 1
so that u can enter to OSPF mode.
Nagendra Kumar ... Tue, 11/27/2007 - 08:35
Hi Paul,
Please be adviced that, it is not mandatory that you need to configure for all class B address. wildcard mask in network command under ospf routing protocol, is just to match the interface IP address and place the same in configured area. For EX:
If you have and address configured in your router which needs to be in area 0, you still can configure "network area 0"
mohindersingh Tue, 11/27/2007 - 09:59
Hi Paulo,
172 is a class B network but OSPF is a classless protocol. so you can configure any mask depending on your requirement.
You can break a single B class into sevral C class networks.
So first see your requirement and if needed then only delete it.
glen.grant Tue, 11/27/2007 - 09:12
Why do you think it is wrong ? You have to look at the interfaces , maybe that particular network is all they want to advertise . That statement is not neccessarily wrong.
Edison Ortiz Tue, 11/27/2007 - 11:36
If you want to enable OSPF on interfaces with subnets mentioned above (132.1.1.* - 132.1.7.*) then yes, it won't work with the current network statement under OSPF.
network area 0
should do the job.
Keep in mind, the list of networks under the OSPF process do not represent the networks that are being advertised -in transit- but the list of interfaces this device has, which you want to enable OSPF.
