Cisco CSS running version 5.02 Build 3, flow-state, SNMP?
Nov 27th, 2007
Trying to figure out how to configure SNMP access to servers located behind a CSS running v5.02003.
It looks like in v6+ flow-state flow-enable needs to be configured, but in v5, I don't see this command.
Does anyone know if the command isn't required because in v5 the CSS already builds flow information for UDP 161, or if it isn't possible in this version of code?
Gilles Dufour Fri, 11/30/2007 - 12:45
  • Cisco Employee,
your version is not suported anymore.
You should seriouslt consider an upgrade to 6.10
Gilles.
