service policy command and QoS
Nov 27th, 2007
When setting up a policy-map containing a class map, and then applying that policy map to either the LAN interface or WAN interface of 2 particular routers, the policy is not getting applied. I type the command in, no errors, however when looking at the interface with show run it reveals no policy map has been applied. I've successfully applied the same policy maps to 2 other routers. Both the problem routers are running IOS 12.4(11)T1
Is there possibly an IOS bug in these versions or something missing in the interface configs?
I've checked out cisco's feature navigator to explore the possibility that the different images, (c2801-ipbasek9-mz.124-11 - router with the problem and c2800nm-advipservicesk9-mz - router without the problem) are the cause, but the only unique QoS related feature on either is QoS Policy Propagation via Border Gateway Protocol (QPPB) on the Advanced IP image and QOS: DirectConnect PDLM on the standard.
I found a 3rd router with the same IOS image that does NOT have the problem. Only 2 of them seem to be exhibiting this behavior.
thank you,
Bill
bvsnarayana03 Tue, 11/27/2007 - 20:55
  • Silver, 250 points or more
Hi Bill,
If i understand clearly, the router accepts the command "ip service-policy output xxx" but doesnt show it in "sh run".
have you tried "sh policy-map interface" to see whether its really applied or not.
WILLIAM STEGMAN Wed, 11/28/2007 - 05:13
that's correct. No errors, the command goes in fine, but is never actually applied to the interface. Yes, I have also used the sh policy-map int if_name command and nothing is returned.
mheusing Fri, 11/30/2007 - 04:23
  • Cisco Employee,
could you provide us the configuration of the policy, class-maps and interface, where the issue occurs?
Regards, Martin
WILLIAM STEGMAN Fri, 11/30/2007 - 05:19
I've tried stripping it down to its simplest form for these 2 particular routers. I have only 1 class map, and 1 policy map and have attempted binding it to several interfaces. I've repeated the process on another router with the same results. Of course however as mentioned previously it works fine on 3 other routers.
SanDiego2801#sh class-map
Class Map match-any BUSINESSCRITICAL (id 1)
Match access-group 151
Match protocol citrix
Match protocol sqlserver
Match protocol http host "timesheets"
Match protocol http host "connect"
SanDiego2801#
SanDiego2801#sh policy-map
Policy Map LANEDGE-MARKING&WORMTRAFFIC
Class BUSINESSCRITICAL
set dscp af31
Extended IP access list 151
10 permit ip any host 10.4.0.72
20 permit tcp any host 10.4.0.54 eq www
30 permit tcp any host 10.4.0.11 eq www
40 permit tcp any host 10.4.0.45 eq www
50 permit tcp any host 10.4.0.72 eq www
60 permit tcp any host 10.4.0.37 eq www
SanDiego2801(config)#int fa 0/1
SanDiego2801(config-if)#servi
SanDiego2801(config-if)#service-policy input LANEDGE-MARKING&WORMTRAFFIC
SanDiego2801(config-if)#do sh run int fa 0/0
Building configuration...
Current configuration : 203 bytes
interface FastEthernet0/0
ip address 10.2.0.1 255.255.0.0
ip accounting output-packets
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip route-cache flow
speed auto
full-duplex
end
WILLIAM STEGMAN Wed, 12/05/2007 - 14:08
I've looked at the logs after applying the service policy commands to an interface and on am getting traceback errors,
this is on the dallas router
*Dec 5 21:58:55.473 UTC: %ALIGN-3-TRACE: -Traceback= 0x61B56CE8 0x613A2EC8 0x613AAB70 0x613AC308 0x614855E8 0x614104AC 0x6141062C 0x6143BBBC
and this on the San Diego router
206.115.117.178: <187>196: Dec 5 22:07:05: %ALIGN-3-SPURIOUS: Spurious memory access made at 0x613B303C reading 0x28
206.115.117.178: <187>197: Dec 5 22:07:05: %ALIGN-3-TRACE: -Traceback= 0x613B303C 0x613AD19C 0x613AD4F8 0x613AC8D0 0x614855E8 0x614104AC 0x6141062C 0x6143BBBC
mheusing Thu, 12/06/2007 - 04:25
  • Cisco Employee,
That does not look too good. If this log entry is related to applying the service-policy command, you might have to use another IOS version to get the desired result.
Regards, Martin
