AIP-SSM system upgrade
Nov 27th, 2007
I've received a new asa5520 with aip-ssm (ssm-20). I have upgraded the ASA image to 7.2(3) successfully. I am trying to upgrade the SSM module from 5.1(6)E1 to 6.0(3)E1. I have the following connections
Sensor IP:
ASA G0/0:
TFTP server:
Subnet: /29
trying to upgrade from the ASA I have issued the commands:
hw-module module 1 recover configure
>Image URL: tftp://
>Port IP address:
hw-module module 1 recover boot
debug module-boot
here is the output I get
Slot-1 64> Cisco Systems ROMMON Version (1.0(11)2) #0: Thu Jan 26 10:43:08 PST 2006
Slot-1 65> Platform ASA-SSM-20
Slot-1 66> GigabitEthernet0/0
Slot-1 67> Link is UP
Slot-1 68> MAC Address: 001c.5826.2083
Slot-1 69> ROMMON Variable Settings:
Slot-1 70> ADDRESS=
Slot-1 71> SERVER=
Slot-1 72> GATEWAY=
Slot-1 73> PORT=GigabitEthernet0/0
Slot-1 74> VLAN=untagged
Slot-1 75> IMAGE=IPS-SSM-K9-sys-1.1-a-6.0-3-E1.img
Slot-1 76> CONFIG=
Slot-1 77> LINKTIMEOUT=20
Slot-1 78> PKTTIMEOUT=4
Slot-1 79> RETRY=20
Slot-1 80> tftp [email protected] via
Slot-1 81> TFTP failure: Packet verify failed after 20 retries
Slot-1 82> Rebooting due to Autoboot error ...
Slot-1 83> Rebooting....
Any ideas on why I'm getting the failure at line 81 would be great!
ghalleen Sat, 12/01/2007 - 00:17
Try it again, but this time don't add a gateway address. If you go to Networkers, I cover this in the Troubleshooting IPS session. It's a frustrating problem when you initially run into it! ;-)
Only add a gateway when the TFTP server is on a different LAN segment than the sensor.
rhermes Mon, 12/03/2007 - 12:08
If your sensor boots into 5.x you can issue the upgrade command
upgrade ftp://user@
It's less complex than re-imaging your sensor from scratch, plus there are less hidden problems that require you to attend a troubleshooting class to discover.
