Cisco 3825 NVRAM Corrupted ?
Nov 27th, 2007
I was working in the router and tried to save the changes, but I got the following error "startup-config file open failed (Not enough space)". Does anyone know of a proper way to fix this issue?
When I tried to do a "show start", I get this error:
sh start
Using 12058 out of 491512 bytes
%Error opening nvram:/startup-config (Bad address)
IOS: c3825-ipvoicek9-mz.124-16.bin
Thanks for any input.
hieu
Hieu Cao Tue, 11/27/2007 - 18:11
Got the issue resolved. Save the running config to another location, then "erase /all nvram:", then issue "wr mem".
It also helps to reduce the size of the config when saving it on NVRAM if you issue this command "service compress-config" globally prior to "wr mem".
hieu
