11-27-2007 06:42 PM - edited 03-05-2019 07:39 PM
Guys i have couple of 6509 running CAtOs....now i want to see ports status interms of last activity recorded on each port.....what i sthe command i tried show port usage....it tell me th elast date it went up or down (i believe so correct me if i m wrong)....i want to know when was the last data activity on each port....can someone please help me out? thanks
11-27-2007 06:48 PM
Hi, you can see the last time your ports had any activity in or out using show int modifiers, these commands reduce show output to smaller detail information. Try this command for data activity, hope it helps.
switchint#show int fa0/22 | inc output
Last input 00:00:18, output 00:00:00, output hang never
5 minute output rate 2000 bits/sec, 3 packets/sec
26896 packets output, 2337231 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
switchint#show int fa0/22 | inc input
Last input 00:00:09, output 00:00:00, output hang never
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 1000 bits/sec, 3 packets/sec
20117 packets input, 1865955 bytes
38 input errors, 37 CRC, 1 frame, 0 overrun, 0 ignored
11-27-2007 08:29 PM
Mate i rekon this command is for IOS i nhave said that i have CATOS it doesnt work on CATOS.......cheers
