SIP/H323/GK CCM question
Nov 27th, 2007
I have a connection like this
SIP IP Phone (5555) connected with CCM6
CCM6 has SIP trunk to GW1, CCM6 has route patten 6666 using this SIP trunk
GW1 is IPIPGW, and also GW1 is a H323 GW registered with GK1
I have another CCM4.2, SCCP IP Phone, number 6666, GK1 has registered in CCM4.2
CCM4.2 has H225 controlled trunk (GK1), and route patten 6666 point to the trunk
so diagram like
5555-SIP-CCM6---GW1---GK1---CCM4.2--SCCP-6666
my question is
when 5555 calling 6666, 6666 is ringing, and after press "answer" on 6666, the call connected shown on 6666, however, 5555 is still ringing, and after few second, 5555 get re-order tone
here is some config and debug, please help
study_voip Tue, 11/27/2007 - 21:37
*Nov 28 05:51:12.615: //-1/C28588368089/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=5555
----- ccCallInfo IE subfields -----
cisco-ani=5555
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=6666
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
*Nov 28 05:51:12.619: //-1/C28588368089/CCAPI/cc_api_call_setup_ind_common:
Interface=0x4653BAC4, Call Info(
Calling Number=5555,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=6666(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE,
Sourc
CUE#e Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=52
*Nov 28 05:51:12.619: //-1/C28588368089/CCAPI/ccCheckClipClir:
In: Calling Number=5555(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=5555(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
*Nov 28 05:51:12.619: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 28 05:51:12.619: :cc_get_feature_vsa malloc success
*Nov 28 05:51:12.619: cc_get_feature_vsa count is 1
*Nov 28 05:51:12.619: :FEATURE_VSA attributes are: feature_name:0,feature_time:1174961240,feature_id:52
*Nov 28 05:51:12.619: //52/C28588368089/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=5555(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=6666(TON=Unknown, NPI=Unknown))
*Nov 28 05:51:12.623: //52/C28588368089/CCAPI/cc_process_call_setup_ind:
Event=0x46094848
*Nov 28 05:51:12.623: //52/C28588368089/CCAPI/ccCallSetContext:
Context=0x4724FFDC
>>>>CCAPI handed cid 52 with tag 10 to app "_ManagedAppProcess_Default"
*Nov 28 05:51:12.623: //52/C28588368089/CCAPI/ccCallProceeding:
*Nov 28 05:51:12.627: //52/C28588368089/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=101, Params=0x47251D7C, Progress Indication=NULL(0)
*Nov 28 05:51:12.627: //52/C28588368089/CCAPI/ccCheckClipClir:
Destination Pattern=6666, Called Number=6666, Digit Strip=FALSE
Redirect Number=, Display Info=
Account Number=5555, Final Destination Flag=TRUE,
Guid=C2858836-9CAC-11DC-8089-B3268B600FE7, Outgoing Dial-peer=101
*Nov 28 05:51:12.627: //52/C28588368089/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=5555
cisco-ani=5555
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=6666
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
study_voip Tue, 11/27/2007 - 21:38
gw1
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
sip
dial-peer voice 10 voip
session protocol sipv2
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 101 voip
destination-pattern 6666
progress_ind setup enable 3
progress_ind progress enable 8
progress_ind connect enable 8
progress_ind disconnect enable 8
session target ras
dtmf-relay h245-alphanumeric
codec g711ulaw
CUE#show gatewa
H.323 ITU-T Version: 4.0 H323 Stack Version: 0.1
H.323 service is up
This gateway is registered to Gatekeeper CCM4
study_voip Tue, 11/27/2007 - 21:40
Gk1
sh gatekeeper endpoints
GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr Port RASSignalAddr Port Zone Name Type Flags
10.1.200.43 50312 10.1.200.43 49600 CCM4 VOIP-GW
H323-ID: CCM4Trunk_1
Voice Capacity Max.= Avail.= Current.= 0
10.1.200.228 1720 10.1.200.228 59778 CCM4 H323-GW
E164-ID: 3001
E164-ID: 3002
Total number of active registrations = 2
sr | be ga
gatekeeper
zone local CCM4 sss.com 10.1.200.3
zone prefix CCM4 6*
gw-type-prefix 1#* default-technology
no shutdown
sh gatekeeper calls
Total number of active calls = 1.
GATEKEEPER CALL INFO
LocalCallID Age(secs) BW
15-13037 4 16(Kbps)
Endpt(s): Alias E.164Addr
src EP: 5555
dst EP: CCM4Trunk_1 6666
study_voip Tue, 11/27/2007 - 21:52
GW1
sr int f0/0
Building configuration...
Current configuration : 255 bytes
interface FastEthernet0/0
ip address 10.1.200.228 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id CCM4 ipaddr 10.1.200.3 1719
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr 10.1.200.228
study_voip Tue, 11/27/2007 - 21:41
correction
CCM4.2 has H225 controlled trunk (GK1), and route patten 5555(not 6666) point to the trunk
study_voip Tue, 11/27/2007 - 21:48
GK1
*Nov 28 05:57:49.327: gk_rassrv_arq: arqp=0x45CEC950, crv=0x32, answerCall=0
*Nov 28 05:57:49.327: gk_dns_query: No Name servers
*Nov 28 05:57:49.327: rassrv_get_addrinfo: (6666) Tech-prefix match failed.
*Nov 28 05:57:49.327: rassrv_get_addrinfo: (6666) Matched zone prefix 6 and remainder 666
*Nov 28 05:57:49.327: rassrv_arq_select_viazone: about to check the source side, src_zonep=0x459CCEA8
*Nov 28 05:57:49.327: rassrv_arq_select_viazone: matched zone is CCM4, and z_invianamelen=0
*Nov 28 05:57:49.327: rassrv_arq_select_viazone: about to check the destination side, dst_zonep=0x459CCEA8
R28GK#
*Nov 28 05:57:49.327: rassrv_arq_select_viazone: matched zone is CCM4, and z_outvianamelen=0
*Nov 28 05:57:49.339: gk_rassrv_arq: arqp=0x456F5B74, crv=0x8032, answerCall=1
study_voip Tue, 11/27/2007 - 21:49
GW1
sh dial-peer voice 101
VoiceOverIpPeer101
peer type = voice, system default peer = FALSE, information type = voice,
description = `',
tag = 101, destination-pattern = `6666',
voice reg type = 0, corresponding tag = 0,
allow watch = FALSE
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 101, Admin state is up, Operation state is up,
incoming called-number = `', connections/maximum = 0/unlimited,
DTMF Relay = enabled,
modem transport = system,
URI classes:
Incoming (Called) =
Incoming (Calling) =
Destination =
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
type = voip, session-target = `ras',
technology prefix:
settle-call = disabled
ip media DSCP = ef, ip signaling DSCP = af31,
ip video rsvp-none DSCP = af41,ip video rsvp-pass DSCP = af41
ip video rsvp-fail DSCP = af41,
UDP checksum = disabled,
session-protocol = cisco, session-transport = system,
req-qos = best-effort, acc-qos = best-effort,
req-qos video = best-effort, acc-qos video = best-effort,
req-qos audio def bandwidth = 64, req-qos audio max bandwidth = 0,
req-qos video def bandwidth = 384, req-qos video max bandwidth = 0,
dtmf-relay = h245-alphanumeric,
RTP dynamic payload type values: NTE = 101
Cisco: NSE=100, fax=96, fax-ack=97, dtmf=121, fax-relay=122
CAS=123, TTY=119, ClearChan=125, PCM switch over u-law=0,
A-law=8, GSMAMR-NB=117 iLBC=116
h263+=118, h264=119
G726r16 using static payload
G726r24 using static payload
RTP comfort noise payload type = 19
fax rate = fax, payload size = 20 bytes
fax protocol = system
fax-relay ecm enable
Fax Relay SG3-to-G3 Enabled (by system configuration)
fax NSF = 0xAD0051 (default)
codec = g711ulaw, payload size = 160 bytes,
video codec = None
voice class codec = `'
text relay = disabled
Media Setting = flow-through (global)
Expect factor = 10, Icpif = 20,
Playout Mode is set to adaptive,
Initial 60 ms, Max 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Fax nominal 300 ms
Max Redirects = 1, signaling-type = cas,
VAD = enabled, Poor QOV Trap = disabled,
Source Interface = NONE
voice class sip url = system,
voice class sip rel1xx = system,
tvoice class sip outbound-proxy = system,
voice class sip asserted-id = system,
voice class sip privacy = system,
voice class sip e911 = system,
redirect ip2ip = disabled
local peer = false
probe disabled,
Secure RTP: system (use the global setting)
voice class perm tag = `'
Time elapsed since last clearing of voice call statistics never
Connect Time = 0, Charged Units = 0,
Successful Calls = 21, Failed Calls = 17, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
study_voip Tue, 11/27/2007 - 21:55
codec should not be a problem, i tried different codec setup on ccm, gw dialpeer etc
