Source Routing ?
Nov 27th, 2007
How to define routing by source ip address ?
Overall Rating: 3 (2 ratings)
Kevin Dorrell Wed, 11/28/2007 - 05:11
Please don't confuse "source routing" with "routing by source address".
Source routing is where the originator plants a special header in the packet that specifies which path the packet must take through the network. Most NetAdmins disable it on their routers because it is a security risk.
What you are after is called "policy routing", and it allows you to route according to the source address of the packet, or according to many different parameters if you want, such as precedence etc. etc.
Kevin Dorrell
bvsnarayana03 Wed, 11/28/2007 - 05:30
Hi Kevin,
Nice to see a reply from you.
My understanding was that both the terms refer the same thing.
I would like to learn more about source-routing, why & when is it used. Any links for reference. I tried searching with keyword but no success.
Its really nice to learn from you people.
nambi_gct Wed, 11/28/2007 - 05:37
I agree with Kevin.Adding to Kevin's explaination, source routing can be subdivided in to two parts.
1) Strict source routing.
Should go ONLY via the routers mentioned in the header.
2) Loose source routing.
Should go via all the routers mentioned in the header.But additional intermediate hops are allowed.
IP options field was used for this.I am not sure if all the implementations support this.But I guess it was a kind of traffic engineering.
bvsnarayana03 Wed, 11/28/2007 - 06:06
Nambi, Kevin
Thanks for the explanation & link. I saw these options in the extended ping, though i used the record option but never tried the others.
It was helpful, thanx.
