ACE - Error: resources in use
Nov 28th, 2007
I try associate resource with new configured context, but I got this error message:
ba-ace1-bbc4/Admin(config)# context MIDDLE
ba-ace1-bbc4/Admin(config-context)# member RC_MIDDLE
what does it mean?
here is a configuration part:
resource-class RC_DEVEL
limit-resource all minimum 10.00 maximum unlimited
resource-class RC_FE
resource-class RC_IAM
resource-class RC_ISP_DATA
resource-class RC_ISP_FE
resource-class RC_MIDDLE
resource-class RC_TEST
context DEVEL
allocate-interface vlan 144
allocate-interface vlan 244-245
member RC_DEVEL
context FE
description FrontEnd segment
allocate-interface vlan 142
allocate-interface vlan 240
allocate-interface vlan 242
member RC_FE
context IAM
allocate-interface vlan 172
allocate-interface vlan 272
member RC_IAM
context ISP_FE
description ISP_FE
allocate-interface vlan 169
allocate-interface vlan 269
member RC_ISP_FE
context MIDDLE
context TEST
description TEST_SEGMENT
allocate-interface vlan 141
allocate-interface vlan 241
member RC_TEST
the same situation (error: resources in use) occurs, if I try associate (unused) resource RC_ISP_FE with new context MIDDLE.
where can be a problem?
danger_mousie Wed, 11/28/2007 - 05:36
I also encountered this. I configured the context first wth acls and loggng running, so when i later created the resource class, the resources were in use as there error said. I got around it temporarily by individually limiting the resources that were not in use. Then when it was appropriate, (and after backing up the configs) I deleted the context, and re-entered the config in the following order:
allocate vlans
member resource-class
What resources are in use for you?: sh res usage
Be aware of bug: CSCse99442 when viewing this output
Caveats and bugs:
Martin Kyrc Wed, 11/28/2007 - 05:46
This workaround isn't helpful :(.
Customer upgraded some of licenses and after this action, is unable to create new contexts (with other as default resource class).
I found bug CSCsg91127 but ACE is running SW version 3.0(0)A1(6.2) and this workaround wasn't helpful (remove and re-add context).
danger_mousie Wed, 11/28/2007 - 06:01
Sorry to hear that, indeed it doesn't sound like much of a work around. If the license mismatch occurred the first time the context was added, chances are it will occur the second time too. Perhaps the actual experts here will have a better idea. ;) I suggest entering the output of sh res usage here as it might be relevant.
danger_mousie Wed, 11/28/2007 - 06:31
From the output it looks like resources were allocated to all contexts ok. Does member [resource-class] appear in the running config?
Martin Kyrc Wed, 11/28/2007 - 06:37
ups, my mistake. it IS license mismatch problem. here is a log output from yesterday:
Nov 27 22:00:33: handle_auto_sync_cli_change_mts:1412 License mismatch with peer occured
I'll try apply workaround again.
Martin Kyrc Wed, 11/28/2007 - 07:52
ba-ace1-bbc4/Admin# sh resource usage sum
Resource Current Peak Min Max Denied
Context: Summary
conc-connections 38169 172959 4800000 22400000 0
mgmt-connections 21 129 3000 14000 0
proxy-connections 54 220 524290 3670016 0
xlates 0 0 524290 3670016 0
bandwidth 15339783 486262514 300000000 3500000000 492
connection rate 244 2427 500000 3500000 0
ssl-connections rate 0 13 5000 35000 0
mgmt-traffic rate 574 655938 62500000 437500000 0
mac-miss rate 0 272 1000 7000 0
inspect-conn rate 0 0 3000 21000 0
acl-memory 157520 157584 7861044 31444174 0
regexp 100 100 0 524288 0
syslog buffer 4194304 4194304 0 2097152 0
syslog rate 504 3332 0 1500 0
syslog buffer is a reason of resource allocation...
we tried define resource class with minimum 0% and restrict minimum individual per resource:
ba-ace1-bbc4/Admin(config-resource)# limit-resource buffer syslog
minimum 10 maximum unlimited
Error: applying resource parameter limit failed
ba-ace1-bbc4/Admin(config-resource)# limit-resource conc-connections
ba-ace1-bbc4/Admin(config-resource)# limit-resource mgmt-connections
danger_mousie Thu, 11/29/2007 - 06:58
Indeed, that was my first suggestion as you may recall. ;) The syslogs will continue to absorb the resources, so if you still can't recreate the context successfully, try to limit the type of logging you are doing, 5 instead of 7 for example. That should get you by until there is a fix for the bug. I haven't found a way to empty the buffer unfortunately.
danger_mousie Sun, 01/27/2008 - 05:19
Hello again,
I seem to have stumbled on a workaround for this issue:
The resource that is overused is buffer syslog as you explained. So if you limit each resource to e.g. 20% individually, and buffer syslog to min 0 max unlim, just to allow the context to become a member of the resource class successfully without causing the Resource in use error (as you have done). Then, go back into the resource class config, and enter limit all min [20] max eq, then negate all of the individually assigned resources, it will show in resource usage that the current has gone down to 20%. So now you can allocate the resources as you wish. I'm also allocating a resource class to the admin context now so that it doesn't swallow up the buffer again.
Hope this helps.
