CDR in CCM 5.x and CCM 6.x
Nov 28th, 2007
Hi all,
I want to ask about CDR raw files comparison between CCM 5.x and CCM 6.x
Is there any difference between the CDR raw files of the two versions ? May be someone who has implemented both versions can show me what are the differences?
For third party billing system applications, they really need to know about this, because if it's different, it means they have to make new codes to support the raw files.
Any reply will be appreciated.
Thanks all.
Wiyandi
Overall Rating: 4 (1 ratings)
Aaron Harrison Wed, 11/28/2007 - 09:01
  • Community Spotlight Award,
    Member's Choice, May 2015
There are a number of changes between versions 4.x and 5/6.x.
The CDR format/definition will change with each version to accomodate new features, and the schema is published on cisco.com.
The way in which CDRs should be obtained has also changed in the Linux model.
In versions 4.x, CDR was in the SQL database and accessed via ODBC.
In 5.x upwards, the CM server outputs CDR to an FTP server, which must be provided by your CDR management application.
Hope this helps
Aaron
Please rate helpful posts....
sr2290723 Thu, 11/29/2007 - 16:46
Hi Aaron,
Thanks a lot. Where can I find the CDR schema as you said before ?
Wiyandi
krishnamurthy.mh Sun, 06/08/2008 - 04:34
We are running UCM 6.1.2.
We are planning to deploy third party call billing software.
Can UCM 6.1.2 will support ODBC connectivity?
