Traffic shaping and available bandwidth
Nov 28th, 2007
i've configured class-based traffic shaping to limit the outgoing traffic to 200Mbit. Now i get an output from the command "show queue gigabitEthernet 0/1" that gives me an available bandwidth of only 150Mbit, what does that mean?
Overall Rating: 4.5 (5 ratings)
s.arunkumar Wed, 11/28/2007 - 02:04
  • Bronze, 100 points or more
The "available bandwidth" under the command sh queue giga0/1 shows the 75% of the total bandwidth,which is available after allocating
25% to default queue.In this case 200Mbps is bandwidh of interface,after asigning 25% to default class,the available bandwidth for all other queue is 150Mbps.
bvsnarayana03 Wed, 11/28/2007 - 02:10
  • Silver, 250 points or more
By default you can use only 75% of the BW configured on interface for traffic, rest 25% is reserved for internal processes.
You may change this value by "max-reserved-bandwidth xx" on interface. Where xx is the value you want to use for traffic. Pls note that it is recommended to keep certain BW reserved for internal proceses, so dont use 100%.
pls rate if helped.
guruprasadr Wed, 11/28/2007 - 02:14
  • Gold, 750 points or more
HI, [Do Rate all HELPFUL POSTS]
While using the max Reserved Bandwidth Feature in the Configuration:
QOS by default reserves 25% of Bandwidth for Internal Processes of CISCO Router.
Do Rate all HELPFUL POSTS.
Best Regards,
Guru Prasad R
